Array variables not possible to import from file to Editor EM63 driver
For the Euromap63 driver some array variables are not imported. This occurs when variables contain a comma in the name. This character is understood as a field delimiter. Even if it is between square brackets.
This behavior has been changed. The separator ',' is now ignored during import under certain conditions:
  1. The comma is between square brackets in an expression.
  2. The content of the brackets is numeric only or contains an asterisk (*).
This is in accordance with Euromap specification 3.9.6 and 3.11.
Item ID: 257411
Version: 11.00 Build: 111398
