Archive Server: Selection resets to previously selected archive after edit or module navigation
The Archive Server showed the previously selected archive after editing or module navigation because the selection state was not preserved and reverted to an earlier selection.
Item ID: 313664
Version: 15.00 Build: 590591
    • In the formula edit dialog, the replace button might be activated, even though no tag is selected
      Summary When the paste button is used to fill a formula into the formula edit dialog for a condition in the Batch control module, the replace (tag) button is activated, even though no tag is selected. Clicking the button won't do anything. ...
    • ETM: Navigating backwards or forwards leads to a new archive selection
      Description Navigating forwards or backwards in the ETM screen led to a new archive selection. The issue has been addressed and the behavior is now as expected. Scrolling does not change the selected archive anymore. The data comes from the local ...
    • IEC61850 Server resets EntryID by any purge of BRCB
      Summary The IEC61850 Server - I/O driver in zenon Logic - resets EntryID to 0 when received purge for BRCB - when client writes */PurgeBuf[BR]=true in this BRCB. It causes that when client purges buffer frequently the Server uses for new Reports the ...
