API - Setting the smart object released property is not correctly saved
The API function ISoReleasedProperty.SetValue() is not executed correctly in the service engine. This has been fixed.
Via the API a property of a Smart Object is released with the function ISoReleasedProperty.SetValue(). After executing the function, the operation is displayed as successful in the Engineering Studio. However, the release does not work in the Service Engine. Only when the release is performed manually in the Engineering Studio, this also works in the Service Engine.
This behavior has been adjusted. The release now also works via the API.
Item ID: 248470
Version: 10.00 Build: 111092
    • Checklist: Smart Client cannot establish a reliable communication
      Time estimate: 60 minutes Please go through all the items in the following checklist. If necessary, confirm any information you cannot verify with the IT department before contacting your local COPA-DATA representative. Checklist usage: #. [Quick ...
    • SO´s released properties are not correctly set when the SO in created via API
      Description When creating an instance of a Smart Object via the API, the released properties may have been set correctly, but the properties of the element within the SO were not set accordingly. This issue has been addressed and the properties are ...
    • Released properties on symbols inside a smart object template do not get updated correctly
      Summary Update of the SOT should work correctly also for symbols and released properties in symbols Description Update of the SOT should work correctly also for symbols and released properties in symbols Issue Number: 226418 Fixed on Date: 15.9.2020 ...
    • SO - Improve Smart Object symbol usage
      Summary The handling of smart objects has been improved.  Description Above all, the following have changed: Multiple application of linking rules (as of zenon 11): This allows zenon Logic variables to be exchanged correctly as well. For this an ...
