The
first SubCondition of an
MultiBinary REMA could not be created using the following API commands:
- State.CreateSubState(); (COM) / ICondition.Create(); (Addin)
(Replied an empty State/ICondition object) - Rema.CreateDynProperty("State[x].SubState"); (COM) / IReactionMatrix.CreateDynamicProperty("State[0].SubState"); (Addin)
(Resulted in an exception: "Given property doesn't exist...[NameOfREMA]::SubState")
Both commands start working after a SubCondition is integrated in the REMA-Condition (manually or via importing an XML which already contains a SubCondition).
The issue has been addressed to allow creation from scratch using API:
If the parent Condition was created using Rema.CreateState() (COM) / Rema.CreateCondition() (Addin), the above commands work.
