An unhandled exception message may occur and the editor or runtime may close unexpectedly, when executing an action on a recipe of the Recipegroup Manager through the API, when the parent Recipegroup object is set to nothing.
Executing an action on a recipe of the Recipegroup Manager through the API after the parent Recipegroup was explicitly set to nothing, caused an unhandled exception message and could cause the editor or runtime to close unexpectedly.
An issue has been addressed in the Recipegroup manager API access where recipe actions executed on a recipe that no longer has a valid Recipegroup parent caused an unhandled exception. Now an action to such a recipe results in an error message in the API.
Issue Number: 32488
Fixed on Date: 11.11.2014
Versions: 7.50 0 BUILD 25796
