An incorrect value in the configuration of the DNP3 process gateway is validated and reported, yet still saved under specific circumstances
If an incorrect value is entered in the configuration of the DNP3 process gateway, the value is validated and the error reported. If the error is not corrected and the dialog is closed with "cancel", the incorrect value is still saved.
An issue has been addressed in the DNP3 process gateway configuration where incorrect values were still saved.
Issue Number: 31173
Fixed on Date: 9.1.2015
Versions: 7.50 0 BUILD 25796
Checklist: Process Gateway cannot start
Checklist: Process Gateway cannot establish a reliable communication
Azure Process Gateway is not responding under specific circumstances
Summary The Azure Process Gateway changes from "OK" to "Not Responding" under specific circumstances. Observed with a zenon project exposing about 2700 variables to Event Hub via json format, and a 5[s] integrity period. This causes theĀ user ...
Checklist: Process is not responding
