Summary zenon uses the comment field of AML and CEL entries to store the values used in dynamic limit texts. In the Alarm List the comment edit box should be disabled for such alarms. However a random value comment is displayed for alarms with ...
Description In a zenon project "Long dynamic limit texts" are disabled for AML or CEL. An entry for reaction matrix or a variable limit value uses dynamic content but does not refer to other variables. For example: " $The value is ;%v". The entry has ...
Summary In Chronological Event List the text of "resource label" field has always black, not default color. The text of the field is not visible on black background. Description In Chronological Event List the text of "resource label" field has ...
In some cases the "Export CEL" function will cut off the Limit Value Text (by using CSV Export) by projects converted from older versions. To fix this effect you need to create a new "Export CEL" function in actual version.
Summary With certain settings the colors for AML/CEL lists are not printed correctly. This has been fixed. Description AML and CEL are printed correctly in the Service Engine with all configured color settings. If the setting "Use status-dependent ...
