Allocation target variables do not correctly consider non-linear value adjustment
A target variable used at an allocation that has macros linked for non-linear value adjustment, doesnot call the AdjustScadaValue macro prior to writing the value if the source variable at the allocation changes the allocation is triggered
Target variables used at an allocation now correctly consider the non-linear value adjustment
Issue Number: 28856
Fixed on Date: 18.2.2013
Versions: 7.00 0 BUILD 7
