All archive files from Server 2 are synched to Server 1 in non dominant redundancy systems because of additional byte in archives.
When operating in non-dominant redundancy, all archive files are always synchronized when switching redundancy from server 2 (as standby) to server 1. This means that even those files that have not changed are synchronized. Synchronization can therefore take a very long time.
Cause:
Server 2, as the active server, always writes one byte more per archive value. Thus all archive files are larger than on server 1 and force the complete synchronization.
This behavior has been changed. Now only those archives are synchronized that have actually changed.
Item ID: 261746
Version: 11.00 Build: 157700
Version: 10.00 Build: 131739
    • FAQ: What are Installation and Security considerations of the zenon Smart Server and Smart Client?
    • FAQ: Initialization of Internal variables (Network) in Dominant redundancy mode.
      When (re-)starting the dominant Server 1, regardless of their 'Remanence' configuration, internal variables with calculation in 'Network' are initialized first in the dominant Server 1 and only after synchronized with the running Server 2. Modules ...
    • Checklist: Process closes unexpectedly (***Non-reproducible***)
