Alarmcauselist starts with an expanded contextlist - taking very long to show up (service engine is blocked)
Loading the Alarm Causes List takes a long time if the Context List is opened with expanded layers and many entries. In the screen of the Context List type, the state on opening can be defined. If the preconfigured dialog in the Service Engine is used instead, the list is always opened completely expanded.
This behavior has been changed. The list is now opened reduced by default.
  • You need to link a user defined context list screen in Project properties
Item ID: 261696
Version: 11.00 Build: 126436
Version: 10.00 Build: 125767
