Alarm Message and Chronologic Event lists visibility may not work correctly in the Runtime.
Alarm Message and Chronologic Event lists may be visible when the value of the variable linked to the visibility property is set to hide before opening the respective screens in the Runtime.
The issue has been resolved so that the visibility of the Alarm Message and Chronologic Event lists is set correctly in the Runtime.
Workaround: Set the visibility variable after opening the Alarm Message/Chronologic Event list screens.
Issue Number: 39176
Fixed on Date: 8.11.2017
Versions: 7.60 0 BUILD 42944 | 8.10 0 BUILD 57250
