Alarm Filter Issue When Using Reactivated Time Option in AML
The AML filter does not work as expected in the Service Engine for alarms with active project property "Use reactivated time". This has been modified.
If an alarm occurs within the set filter time, it is
indicated correctly. If this alarm is reactivated within this filter time, it
is also indicated correctly. If the alarm time is in the filter but the "Use reactivated time" is outside the filter time, the alarm is
unexpectedly not indicated.
This behavior has been modified. The AML filter considers as well the alarm reception time as alarm reactivation time.
To benefit from this adjustment:
- Update your zenon Software Platform to the latest build of zenon 10
or higher.
Item ID: 283327
Version: 14.00 Build: 257014
Version: 10.00 Build: 258580
AML continuous export writes wrong reactivated time
Summary All 3 reactivated time columns (time, time internal and time external) are now set correctly: null until the alarm is reactivated, then the internal, external and overall columns based on available timestamps when the alarm is reactivated. ...
Description In the AML, the time for “time reactivated” is entered incorrectly when writing alarms with continuous export export to an SQL database or to a Service Grid Data Storage. Instead of the correct time for the reactivation of the alarm, the ...
Alarm Status column does not correctly display active alarms when the setting "Use Reactivated Time" is used in project under specific circumstances
Summary The Alarm Status is not correctly displayed as "active" under specific circumstances when the option "Use Reactivated Time" is used in the project. If an alarm for a variable becomes acive, than clears (without acknowledging the alarm) and ...
The Extended Trend screen may present an unexpected behaviour when applying the “No time filter” option via the Time/Lot filter screen in the runtime.
Summary The option “No time filter” of the Time/Lot filter screen leads the Extended Trend screen to present an unexpected behaviour in the runtime as this type of time filter is not supported by the Extended Trend screen. DescriptionThe option “No ...
It takes long to display the AML and CEL filter if there are many Alarm Areas in the Global project.
Summary If Global project (in Editor) contains many alarm areas, then in the Runtime, to open the filter dialog in AML or CEL screen, in the integration project, takes significant time. The more sub-projects included - longer it takes. For example in ...
