Alarm does not get the correct background color when a reactivated alarm is acknowledged
When a reactivated alarm is acknowledged, it does not get the configured background color. This happens even though "Use status-dependent text/background colors" was selected for the “Alarm/event class color” property.
This bug has been fixed. For reactivated alarms, the status-dependent text and background color is used when acknowledging, if it has been configured.
Item ID: 263815
Version: 11.00 Build: 157700
    • AML continuous export writes wrong reactivated time
      Description In the AML, the time for “time reactivated” is entered incorrectly when writing alarms with continuous export export to an SQL database or to a Service Grid Data Storage. Instead of the correct time for the reactivation of the alarm, the ...
    • Alarm Filter Issue When Using Reactivated Time Option in AML
      Summary The AML filter does not work as expected in the Service Engine for alarms with active project property "Use reactivated time". This has been modified. Description If an alarm occurs within the set filter time, it is indicated correctly. If ...
    • Set colors of color palette to zenon elements via API.
      Colors in zenon are a 3-byte code of RGB values. The value #EB29D6 corresponds to a strong pink tone. If these colors are linked directly to a zenon object exactly this value is entered in the dynamic property of the element, screen, textcolor, ...
