Alarm classes assignment gets lost
Alarm groups and alarm classes from the global project
can also be selected in a reaction matrix of a local project. However, after
selection via the "Alarm/event group" or "Alarm/event
class" option, the selection is discarded when the dialog is closed or
when another option is configured.
This error has been fixed. Alarm groups
and alarm classes can also be selected from the global project
again as expected.
Note: If alarm groups and alarm classes
have the same name in the local project and global project, the elements from
the local project are used.
- Update your zenon Software Platform to the latest build of zenon 8.00 or
higher.
  Item ID: 139624
 Version: 8.00 Build: 48821
- Related Articles
- Alarm classes assignment gets lost- Summary Global Alarm Classes/Groups in Remas are saved correctly. Was an coding error. during last years changed in the Alarm Class/Group Selection. Remark: New Feature from last year: If Alarm class/Group in global and local Project have the same ...
- Engineering DynProperties: Alarm Groups, Alarm Classes, Alarm Areas- Note, that the single items DynProperties are not addressed as a singular: AlarmGroup AlarmClass AlarmArea ...but within the Collection of: AlarmGroups AlarmClasses AlarmAreas This VBA example addresses the description fields: Public Sub ...
- Alarm aggregation via equipment modell using alarm classes from global project does not work- Summary Linkage to alarm classes is now id based also in the equipment model groups. So it also works with alarm classes for global project. I did the same for all the variables that can be linked to a group (not only alarm linkage but also for net ...
- Numerical prefixes of Alarm groups/classes/areas are not correctly sorted in AML filter- Summary Alarm groups/classes/areas in lists in AML filter are sorted as text. But as they starts with the number (property "No.") the order is not correct: 1, 10, 11,..19, 2, 20, 3 etc. When converted to string the numbers 1..9 should have leading ...
- Alarm areas: wrong value of status variables of linked Alarm Classes when number of alarms exceeds the size of ring buffer- Summary If the number of alarms exceeds the size of the ring buffer, the status variables of linked Classes in Alarm areas are calculated wrong. Description If the number of alarms exceeds the size of the ring buffer, the status variables of linked ...
