After XML import of an exported RGM function the parameter “Overwrite existing file“ is inverted.
The parameter “Overwrite existing file“ is inverted after importing the XML of a RGM function.
The parameter is now correctly imported from the XML file and keeps the correct setting.
Issue Number: 36043
Fixed on Date: 7.11.2016
Versions: 8.00 0 BUILD 46644
