after successful command the TIMEOUT bit by response variable stays on
When before the command the RV has already the same value as CO variable, and when RV has TIMEOUT status bit, then after successfully terminated execute - the RV variable keeps the TIMEOUT bit.
Now on start of a command the TIMEOUT bit on the response variable is always set back
Issue Number: 29942
Fixed on Date: 1.12.2014
Versions: 7.20 0 BUILD 17768
