After startup of the runtime, incorrect measurement readings may be sent to the connected SAP system
In a project where measurement readings for SAP are configured, it can happen, that a value will be provided to the SAP system after a runtime start, before the variable value is actually available in the system. As a result there are incorrect values (0) stored in the SAP system.
An issue has been addressed where measurement readings were sent to the SAP system, although the used variable had no valid value. After the fix, no measurement readings are created, when the variable has no valid value.
Issue Number: 32425
Fixed on Date: 17.12.2014
Versions: 7.20 0 BUILD 17768
