After restoring a workspace backup, equipment modeling is missing
After restoring a workspace backup successfully, the equipment modelling in the global project is missing.
An issue was addressed in the backup module for restoring workspace backups. Now, the equipment modelling is restored properly.
Fixed on 25.04.2013, available in 7.10 SP0 Build 6571
Issue Number: 29482
Fixed on Date: 25.4.2013
Versions: 7.10 0 BUILD 6571
Checklist: Workspace/Project cannot be created, loaded or backed up
"The docfile has been corrupted." while restoring a backup from zenon 5.50
While you restore a backup from zenon 5.50 in a higher version as 7.20 (7.60 / (8.x) you get in the editor an error text: "The docfile has been corrupted." or, if you setup the editor in German: "Die Dokumentendatei wurde beschÃĪdigt" Till version ...
Duplicate equipment group links break metadata synchronization to Asset Modeling
Description When an equipment group was linked more than once to a variable, archive, ... this resulted in the error message "the object to add is already used in this association" in metadata synchronization to Asset Modeling. The issue has been ...
zenon 14/12 - Engineering Studio Crash restoring Workspace
Description In zenon 12, trying to restore a workspace from a previous version can lead to a crash. This is related to the handling of certain constellations in the alarm configuration. To avoid the error a workaround exists: The alarm areas are ...
