Adding a comment to a CEL object via the API in the CelItemAdded event, causes the CELItemAdded event to be executed multiple times
When a comment is entered for a CEL entry via the API, using code executed in the CelItemAdded event, the CelItemAdded event is executed multiple times
An issue was addressed where entering a comment generated a CelItemAdded event, causing a recursive call when the comment was made in the CelItemAdded event itself. Now entering a comment for a CEL Entry no longer triggers a CelItemAdded event
Issue Number: 28891
Fixed on Date: 18.2.2013
Versions: 7.00 0 BUILD 7
