AddinFramework Bug (Packing of zip files)
The timeout of building a scadaAddIn package is now set to 30sek (former 8Sek). If this timeout is exceeded a error message is shown and the build fails. (former an invalid package was created)
Issue Number: 171393
Fixed on Date: 11.1.2019
Versions: 7.60 0 BUILD 54483 | 8.00 0 BUILD 55271
Description If a project is built several times, the results for Add-Ins may vary: Sometimes a valid *.scadaAddin file is created, sometimes a corrupted one and sometimes no *.scadaAddin file at all. Cause: If packaging takes longer than 8 seconds, ...
FAQ: How to prevent corrupted files after power outage?
Read the attached PDF files (English/German) for more information on how to set up your system to avoid corrupted files in case of an power outage.
zip files created with the System Information Collector (SIC) can“t be opened
Summary In rare cases it can happen that zip files which have been created with the System Information Collector (SIC) could not be opened again. Instead, the error message "Attempt to access an unnamed file past its end" is displayed. DescriptionIn ...
FAQ: How to import external vector graphic files in zenon?
Import of vector graphics (DXF and PLT files) is not available for the 64-bit Engineering Studio, so that this can only be done in 32-Bit Engineering Studio. To start 32-Bit Engineering Studio, in the zenon Startup Tool right-click on the respective ...
ThreeDElement files are deployed unsigned
Description The listed files in the BUG were deployed unsigned. The issue has been addressed and the listed files are signed now before the deployment packages are "created". To benefit from this fix: Update your zenon Software Platform to the latest ...
