AddinFramework Bug (Packing of zip files)
If a project is built several times, the results for Add-Ins may vary: Sometimes a valid *.scadaAddin file is created, sometimes a corrupted one and sometimes no *.scadaAddin file at all.
Cause: If packaging takes longer than 8 seconds, an invalid Add-In file is the result of the build process. However, a successful build is indicated.
This error has been fixed. The timeout for creating a scadaAddIn package has been increased from 8 seconds to 30 seconds. If this timeout is exceeded, the build fails and an error message is displayed.
  • Update your zenon Software Platform to the latest build of zenon 7.60 or higher.
Item ID: 171393
Version: 8.00 Build: 55271
Version: 7.60 Build: 54483
    • AddinFramework Bug (Packing of zip files)
      Summary The timeout of building a scadaAddIn package is now set to 30sek (former 8Sek). If this timeout is exceeded a error message is shown and the build fails. (former an invalid package was created) Description The timeout of building a scadaAddIn ...
    • FAQ: How to prevent corrupted files after power outage?
      Read the attached PDF files (English/German) for more information on how to set up your system to avoid corrupted files in case of an power outage.
    • zip files created with the System Information Collector (SIC) canĀ“t be opened
      Summary In rare cases it can happen that zip files which have been created with the System Information Collector (SIC) could not be opened again. Instead, the error message "Attempt to access an unnamed file past its end" is displayed. DescriptionIn ...
    • FAQ: How to import external vector graphic files in zenon?
      Import of vector graphics (DXF and PLT files) is not available for the 64-bit Engineering Studio, so that this can only be done in 32-Bit Engineering Studio. To start 32-Bit Engineering Studio, in the zenon Startup Tool right-click on the respective ...
    • ThreeDElement files are deployed unsigned
      Description The listed files in the BUG were deployed unsigned. The issue has been addressed and the listed files are signed now before the deployment packages are "created". To benefit from this fix: Update your zenon Software Platform to the latest ...
