Addin Editor Service cannot be started and are not shown in menu entry Manage Editor services...""
This issue has been solved. Editor Services are shown again.
Issue Number: 127417
Fixed on Date: 26.1.2018
Versions: 7.60 0 BUILD 44685
    • Using AddIn in combination with WVS
      Can AddIns be used in WVS? Simple answer: yes, but... Types of AddIns, Types of WVS There need to be distinguished between a AddIn Service and an AddIn Wizard. Whereas the first is started and stopped and reacts in between on events is the latter ...
    • How to get the IIoT Dashboard Service running with data from the Service Engine
    • Checklist: The Logic Service to Service Engine connection does not work
      Time estimate:   30 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Screenshot and followed ...
    • Checklist: Problems of displaying graphics in Service Engine
      Time estimate:  15 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Checklist usage: #. [Quick ...
