ActiveX controls are producing memory leaks in the Runtime
The destructor CWindowlessControl::~CWindowlessControl() is never called.
issue was addressed in AvtiveX control managing object.
Issue Number: 29686
Fixed on Date: 31.5.2013
Versions: 7.00 0 BUILD 10
    • Checklist: ActiveX control element
      Time estimate:  30 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Screenshot and followed ...
    • zenon Runtime ActiveX element. CD_ListBox size changed after selecting the list box at the zenon Runtime.
      Summary When a zenon screen includes an ActiveX element CD_ListBox the list box has at the zenon Runtime a smaller size as at the zenon Editor. If selecting the list box once a time the size will be changed. The issue may also occur after changing ...
    • ActiveX control for zenon Runtime ends unexpectedly when inserted in a VBA form (Excel).
      Summary ActiveX control for zenon Runtime ends unexpectedly when inserted in a VBA form (Excel). DescriptionActiveX control for zenon Runtime ends unexpectedly when inserted in a VBA form (Excel). Solution Issue was addressed in license check for ...
    • [AccessOpcUa] Memory leaks
      Description When establishing a connection to the OpcUAServer, connection problems occurred sporadically. The issue has been addressed and the establishing of a connection works now as expected. To benefit from this fix: Update your zenon Software ...
    • Checklist: Update CE fails
      Time estimate:   15 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Screenshot and followed ...
