AccessOPCUA: under specific circumstances the OPC UA server incorrectly assumes that the session has timed out
Potential race-condition in multithreading environment resolved by calculating timeout in same thread.
Issue Number: 228845
Fixed on Date: 2.11.2020
Versions: 8.00 0 BUILD 69124 | 7.60 0 BUILD 69540
    • How to use certificates for OPC UA security
    • FAQ: How can I browse an OPC UA Server using the zenon OPC UA Client Driver?
    • OPC-UA Server: DNS Name used in certificate created by zenon.
    • How to setup the zenon OPC UA Driver with a CA-signed certificate
    • How to setup the zenon OPC UA Driver with a self-signed certificate
