AccessOPCUA: Takes very long time to start with Customer project
In the Process Gateway,
AccessOPCUA takes a long time to start in some projects.
This is due to the number of variables contained in
the project. All variables have been checked to see if they have been
configured in the Process Gateway.
The checking process has been revised. Now only
relevant variables are checked. AccessOPCUA now starts as quickly as
expected.
- Update your zenon Software Platform to the latest build of zenon 10 or
higher.
Item ID: 270912
Version: 12.00 Build: 206562
Version: 11.00 Build: 182164
Version: 10.00 Build: 195250
Project in zenon Logic takes long time to compile and eventually Stops responding.
Description A zenon Logic project takes a very long time to compile and may even stop responding. This can also affect the Engineering Studio. This mainly occurs when UDFBs are shared across several projects. This error has been fixed. Compiling a ...
Project in zenon Logic takes long time to Build external POUS when added manually
Description zenon Logic projects take a long time to load external POUs manually. This behavior has been modified. The loading times of POUs have been significantly reduced. To benefit from this fix: Update your zenon Software Platform to the latest ...
Second Loading Time of Project analysis is higher then in previous Versions
Summary The project analysis takes an unusually long time when it is run again. This behavior has been fixed. Description If the project analysis has already been executed once, the execution time should be significantly shorter when it is started ...
