AccessOPCUA.dll: Gateway generates duplicated MonitoredItemNotifications
The zenon OPC UA Process Gateway generates
duplicate notifications for Monitored Items for a single value change of a
variable.
This happens if the size of the queue for
Monitored Items notifications is configured larger than 1 for the connected OPC
UA clients.
This behavior has been corrected. >
To get the correct number of notifications
again:
- Update to the latest build of zenon 8.10, 8.20, 10
or 11.
Item ID: 243079
Version: 8.20 Build: 88924
Version: 8.10 Build: 88647
Summary The AccessOPCUA server no longer sends duplicate MonitoredItemNotifications in one responce. Description The zenon OPC UA Process Gateway generates duplicate notifications for Monitored Items for a single value change of a variable. This ...
Process Gateway SNMP: AccessSNMP.dll is missing or misconfigured
Summary Due to a wrong dependency specification, the SNMP process gateway dll "AccessSNMP.dll" could not be loaded by the Windows SNMP service. The dependency is now specified correctly and the process gateway works as expected. Description Due to a ...
Crash Exception 0xC0000005 AccessOPCUA.dll!cs::opcua::server::CSubscription::getSessionId
Description The OPC UA Process Gateway causes Exception 0xC0000005 in some situations when reloading. This has been fixed. The OPC UA Process Gateway routine for Subscription/Session management has been improved, assuring robust reload and reconnect ...
Checklist: Process Gateway cannot start
AccessOPCUA with CUSTOM_NODESET crash after reload
Description The AccessOPCUA Process Gateway crashed during reload when a Custom NodeSet was active because the reload forced a cold restart due to an invalid certificate. The issue has been addressed and the behavior is now as expected. To benefit ...
