AccessMODBUS: Process Gateway cannot be started via startup tool
The Modbus Process Gateway (AccessMODBUS) could not be started via the Startup tool.
The issue has been addressed and the start via the Startup tool works again now.
Item ID: 286616
Version: 12.00 Build: 301428
Version: 11.00 Build: 314353
    • Checklist: Process Gateway cannot start
    • Checklist: Process Gateway cannot establish a reliable communication
    • Checklist: Process is not responding
