AccessIEC870Slave hangs during shutdown
When the Service Engine is terminated, AccessIEC870SL is not terminated correctly in the Process Gatway. This means that the Service Engine and drivers are also not terminated.
This behavior has been fixed. All components are now terminated correctly.
Item ID: 259529
Version: 11.00 Build: 115310
    • Compatibility problem with Access IEC60870-5-104, can't load setting from XML
      Description After updating zenon Software Platform to a build that supports IPv6, IEC870 Master does not get a connection to IEC870 Slave in 101-Unbalanced mode.. This has been fixed. To benefit from this fix: Update your zenon Software Platform to ...
    • Webclient and server hangs if Reports are executed
      Summary When executing Reports (Module: Report Generator) in a project leads in network projects to the issues: - Server hangs if you open several pics - Webclient crashes if you open several pics Description When executing Reports (Module: Report ...
    • Access IEC870Sl crash during shutdown Service Engine process
      Description When terminating the Service Engine, the slave for the IEC60870-5-101/104 protocol in the Process Gateway causes an Unhandled Exception. This problem has been solved. To benefit from this fix: Update your zenon Software Platform to the ...
    • zenon Runtime hangs when CEL or AML file reaches size of 4GB.
      Summary zenon Runtime hangs when CEL or AML file reaches size of 4GB. Description zenon Runtime hangs when CEL or AML file reaches size of 4GB. Solution Issue was addressed in index of entry position in CEL and AML files larger then 2GB. Now files ...
    • IEC60870 Slave PG - IOA 16 internal variable not updated correctly
      Description The IEC60870 Slave driver did not update the PG - IOA 16 internal variable correctly. The issue has been addressed and the PG - IOA 16 variable is updated now correctly. To benefit from this fix: Update your zenon Software Platform to the ...
