AccessICCP: support for SBO as ICCP client via command processing
The AccessICCP Process Gateway as an ICCP client has been extended to support Select Before Operate for objects of the Device object type.
Note: The VMD-specific/Domain-specific configuration option in the General tab of the Client option group only affects objects of the Variable type. In the ICCP client, the Device objects are always addressed in a domain-specific manner.
For this purpose, the Extended type option group has been adapted in the configuration dialog in the Client Variable tab: If the Object typeDevice object is activated for a variable, the new options None SBO and SBO are now offered for selection in the existing Extended type option group. In addition, the Check back ID can be configured via an option. With Select, the Check back ID is read. The Select is positively completed when the value has been successfully read and matches the configured value.
New status values for SBO device objects:
  • 1001: SELECT in progress
  • 1000: SELECT successful
  • 1002: SELECT check back ID mismatch
  • 1200: SELECT check back ID read error. 1200 + MMS error code.
Item ID: 279736
Version: 10.00 Build: 314352
