Access OPCUA automatic certificate is not created anymore
An OPC UA Process Gateway configured in the Engineering
Studio no longer creates a certificate in zenon 11 when the Service Engine is
started for the first time. This means that the online communication cannot be
initialized.
This error has been fixed. The OPC UA Process
Gateway creates the required certificate again.
higher.
Item ID: 268187
Version: 11.00 Build: 162879
OPC-UA Server: DNS Name used in certificate created by zenon.
How to setup an own Root Certificate Authority (CA)
This article describes how to setup an own Root Certificate Authority (CA) that allows to sign certificates and create Certificate Revocation Lists (CRL). Setting up an own Root CA simplifies the certificate management in a larger installation, as ...
This article describes how to create a self-signed certificate for using it with the zenon OPC UA Driver. Pre-requisites xca: X certificate and key management zenon Engineering Studio Creating a self-signed certificate using xca Start the xca tool ...
This article describes how to create a certificate signed by a Certificate Authority (CA) for using it with the zenon OPC UA Driver. Pre-requisites xca: X certificate and key management xca database containing the certificate and private key of the ...
How to setup the zenon OPC UA Process Gateway with a CA-signed certificate
This article describes how to create a certificate signed by a Certificate Authority (CA) for using it with the zenon OPC UA Process Gateway. Pre-requisites xca: X certificate and key management xca database containing the certificate and private key ...
