A recording cycle more than 1 hour can result in a wrong cycle when the moment is close after the time when the daylight saving switches to summer.
In the Historian, a recording cycle of more than 1
hour leads to incorrect cycles if the recording time is shortly after
the changeover from standard time (STD) to daylight saving time (DST).
This behavior has been changed for
European Standard Time (CET) and European Summer Time (CEST).
In these time zones, switching to DST or back to STD has no
effect on the recording cycle any more.
- Update your zenon Software Platform to the
latest build of zenon 14 or higher.
Attention: In all other time zones, changing from STD to DST and
vice versa may still result in invalid recording times. This can happen if
the following conditions are met:
- Cycle time greater than 1 hour
- Cycle time smaller than one month
- Time
zone is outside CET/CEST
Item ID: 252007
Version: 11.00 Build: 157700
FAQ: What is the time zone and time format used in zenon Software Platform products and what needs to be considered?
When you ask someone what the time is, they'll usually be able to tell you. But when you ask them what date and time sunrise was yesterday in a different country on a different continent, in a different hemisphere it gets less easy. Terms like GMT ...
File Inspector: Time zone field does not considers the daylight saving period of a time zone
Description In the File Inspector, the daylight saving time is not correctly displayed in the "Time zone" drop-down list. Instead of "UTC+2:00", "UTC+1:00" is displayed. However, the calculation is done correctly with an offset of "UTC/GMT + 2 ...
Zenon drivers: driver closes unexpectedly after receiving a timestamp referring to 1.1.1970 in a time zone with negative offset and daylight saving active
Summary Driver closes unexpectedly after receiving a timestamp referring to 1.1.1970 in a time zone with negative offset and daylight saving active Description Driver closes unexpectedly after receiving a timestamp referring to 1.1.1970 in a time ...
If automatic daylight saving time adjustment is turned off in Windows CE, time stamps are displayed incorrectly in the runtime
Summary If automatic daylight saving time adjustment is turned off in Windows CE, time stamps are displayed incorrectly in the runtime. Time stamps will be displayed with current hour plus the according adjustment for the timezone, but no DST time. ...
