When a runtime reload is triggered while editing a Batch Control recipe, then a message box pops up, asking if you want to save changes. YES would then save the recipe, NO would leave the recipe as it is. This means the unsaved recipe will be maintained as it is.
Normally, when a reload is performed the user should not have to bother with this. So the message box should not appear. Instead, the recipe should be maintained until after the reload.
After fixing the described issue, the message box does not appear any more in the case of reloading the runtime. After the reload, the recipe appears identical as before.
Issue Number: 29386
Fixed on Date: 11.11.2013
Versions: 7.20 0 BUILD 17768
