A dot in the lot name leads to an incorrectly displayed file name when using the archive export function
In the archive export, the lot name is displayed incorrectly if it contains a dot. This has been fixed.
Certain characters for the lot name are forbidden in the archive export function. These forbidden characters do not contain the "dot" character. However, if a dot is used, the lot name is truncated after the first dot. For example, “abc.123.txt” becomes “abc.txt”.
This behavior has been modified. Dots are interpreted correctly again and the name is displayed in full.
Note: If the lot name contains forbidden characters, these are replaced by an underscore. For example, „abc/123.txt“ then becomes „abc_123.txt“.
  • Update your zenon Software Platform to the latest build of zenon 8.20 or higher.
Item ID: 249934
Version: 10.00 Build: 97200
Version: 8.20 Build: 97396
