7.10 startup tool is overwritten by the 7.00 build Setup
When having installed version 7.10 and version 7.0 on the same system and installing a build setup for version 7.0, the 7.10 startup tool gets overwritten by the 7.00 build setup
An issue has been addressed in the build setup. Now the build setup no longer overwrites a newer version of the startup tool.
Issue Number: 28764
Fixed on Date: 19.2.2013
Versions: 7.00 0 BUILD 7
Checklist: Software Platform build update fails
Files that are not overwritten by the build setup should be logged in the log file
Summary If a file in the ProgramData folder was changed by the user, the build setup does not overwrite the file. There is no information in the logfile that the file was not overwritten. DescriptionIf a file in the ProgramData folder was changed by ...
AccessMODBUS: Process Gateway cannot be started via startup tool
The Modbus Process Gateway (AccessMODBUS) could not be started via the Startup tool. The issue has been addressed and the start via the Startup tool works again now. To benefit from this fix: Update your zenon Software Platform to the latest build of ...
Unexpected shutdown of the startup tool when registering a version
Summary In rare cases it happens that the startup tool closes unexpectedly whenstarting the zenon editor of another version than the one which is currently registered. Description In rare cases it happens that the startup tool closes unexpectedly ...
Name of startup tool entry gets lost while editing
Summary When creating a new entry for the startup tool and activating the option 'take over ini settings', then the previously entered name will be cleared. Description When creating a new entry for the startup tool and activating the option 'take ...
