3S_V3 - Simulation Mode doesn't work on Variables imported through the driver
If the 3S_V3 driver is set to "simulation static", Variables imported through that driver can not be changed with dynamic elements.
The import sets the block array size to 0 when importing.
The problem was addressed in the import. The block array size properties are now set properly.
Issue Number: 33874
Fixed on Date: 13.3.2015
Versions: 7.11 0 BUILD 18678 | 7.20 0 BUILD 18778
