3S_V3 Driver - Variables which are currently being monitored in the Runtime are not updated correctly if additional variables are advised when communicating via Gateway V2.3.
If variables are being monitored in the Runtime via Gateway V2.3, an issue can occur when more variables are added to the monitored list. The variables are then not updated correctly in the Runtime. Modified variable values are however still correctly written to the PLC.
An issue has been addressed where the additional monitored variables are now added correctly to the list. All variables are now correctly updated in the Runtime when using the 3S_V3 Driver via Gateway V2.3.
Issue Number: 36363
Fixed on Date: 27.4.2016
Versions: 7.20 0 BUILD 28103 | 7.50 0 BUILD 28116
