When writing a value to a bool variable with the set value function it takes 10 seconds to write and read back the value.
Set a value via element works fast.
Rework the handling of requests in the driver.
General hint: If you have a toggle function in use, it is recommended to enable the property 'always read variable' in the Variables properties. (former 'DDE Active')
