3S_V3 Driver : The Driver object type "Alarm variable" does not support the data types DINT and UDINT
The 3S_V3 Driver object type "Alarm variable" now supports the data types DINT and UDINT
Issue Number: 35102
Fixed on Date: 23.9.2015
Versions: 7.20 0 BUILD 22955 | 7.50 0 BUILD 25796
3S_V3 driver object type Alarm Event does not support USINT
Summary When choosing the Driver Object Type Alarm Event of the 3S_V3 driver, the data type USINT is not available. DescriptionWhen choosing the Driver Object Type Alarm Event of the 3S_V3 driver, the data type USINT is not available. Solution The ...
Cannot create a CTI variable using driver object type V Memory
Summary In zenon 7.10 Editor (32 & 64 bit), if you have a pre-existing CTI variable, you cannot change its driver object type from K-memory to V-memory. Note: Even with creating a new variable based on CTI driver, V Memory object Type, REAL Datatype, ...
