3S_V3 crash after reload
For a project running on the Service Engine, the PLC settings are changed in the Engineering Studio for the 3S_V3 driver. Afterwards  the Service Engine files are transferred. When reloading the project in the Service Engine, the driver crashes.
To avoid this error:
  • Update to the latest build of zenon 10 or 11.
Item ID: 254581
Version: 11.00 Build: 104641
Version: 10.00 Build: 103999
    • Checklist: Process closes unexpectedly (***Non-reproducible***)
    • AccessOPCUA with CUSTOM_NODESET crash after reload
      Description The AccessOPCUA Process Gateway crashed during reload when a Custom NodeSet was active because the reload forced a cold restart due to an invalid certificate. The issue has been addressed and the behavior is now as expected. To benefit ...
    • Checklist: Process closes unexpectedly (***Reproducible***)
    • RT crash after reload - changes made in variables
      Summary Sometimes ServiceEngine crashes after reload if archive evacuation fails immediately before the reload Description Sometimes ServiceEngine crashes after reload if archive evacuation fails immediately before the reload Issue Number: 247623 ...
    • The value (%v) in the dynamic limit text is not converted into the secondary unit
      Summary A dynamic limit text may be configured to display a variable´s value with the placeholder %v. It may further more be configured to display the variable´s measuring unit with the placeholder %u. If unit switch is enabled and the secondary unit ...
