3S_v3: after a reconnect, RDA data could not be read
After a loss of communication, the 3S_v3 driver could reconnect to the PLC and all variables can be read, but the RDA values get not archived any longer.
Issue Number: 182368
Fixed on Date: 22.5.2019
Versions: 7.60 0 BUILD 57804 | 8.00 0 BUILD 59775 | 8.10 0 BUILD 59911
3S_V3 Driver - Real-time data acquisition (RDA) variables are not handled correctly for V2.3 connections.
Summary Real-time data acquisition (RDA) variables are not handled correctly for V2.3 connections. RDA does however work correctly for V3 Connections. DescriptionReal-time data acquisition (RDA) variables are not handled correctly for V2.3 ...
FAQ: How can I backup the Service Engine data, the data created during Service Engine?
The path of the Service Engine folder can be amended in the project properties and it is set into zenon6.ini (VBF30=) when the start project is set in Engineering Studio or in zenon Startup Tool. In the Service Engine folder, there is the subfolder ...
