3S_ARTI_NG driver does not correctly communicate to CoDeSys runtime on devices with Motorola byte order (Big Endian)
The current 3S_ARTI_NG driver only supports communication to CoDeSys runtime on little Endian devices. The driver should also support the connection to devices with Big Endian targets.
 The 3S_ARTI_NG driver has been enhanced with a configuration option to support communication to targets with "Motorola Byteorder" (Big Endian) for each station in the driver configuration. Now communication to targets with Big Endian is also possible.
Issue Number: 28719
Fixed on Date: 4.2.2013
Versions: 7.00 0 BUILD 7
