3D configuration Tool cdwpf
3D Configurator in zenon
Some of you might have noticed that the 3D Configurator tool is gone in the zenon Startup Tool once you solemnly installed zenon 12 or above. This is stated in the help and was a product decision made on good purpose.
If you still want to make some configuration in your 3D cdwpf files you can install the 3D Configurator tool using a separate installer.
The msi installer files in the attachment can help you with that. Execute both of them with admin rights.
Execute the with in a command shell to get extra logs:
  1. msiexec /i <xxx.msi> /Lv* <Logfile-Path>
