Zenon OPC UA Server Issue
I am using Zenon Version 7.60, here I am using STRATON to simulate an OPC UA Server. I have configured accordingly and tested internally with OPC expert on the local host and it is working perfectly fine. Now the problem arises when try to fetch the data from my production server. There is a firewall in between where the corresponding OPC port is opened for communication. When I extract the variables, they are displayed. But when I see the status in Zenon it is showing as INVALID. Even the OPC Expert in the Server is showing the Status as BAD. Our IT Team suspects the difference in Operating system. The OPC UA Server is running on Windows 7 SP1 and the Server which is fetching is Server 2012. Will there be a problem in Exchanging of Certificates between the different OS? If NO what can be the reason behind this? Is there any other port to be opened for data flow?
This is a migrated post! Originally posted on 20.05.2019 by user Praveen Kumar Karthikeyan. Please be aware that information can be outdated.
