Zenon 7.2 with new build
Hello support,
For one of our project, zenon 7.20 is using with DNP3 master to integrate with GE RTU and read data ( digital inputs outputs and analog inputs), we had issue of reading correct analog data from GE RTU, and our engineer sent you about this problem, and COAPA data sent him this build to solve the issue (SCADA720SP0Build26116), and after he installed the build, reading alanlog inputs form GE issue has been solved, but another problem came : we are not able to send control command to the breakers and if we remove the build control is working fine.....
This is a migrated post! Originally posted on 29.05.2016 by user yara. Please be aware that information can be outdated.
