I am going to fill this and run it, but I have problems in different parts of it, what exactly should I do? Can you give me an example or tell me the path of the folder that should be given to it, especially the target folder part?
a) Runtime server: Computer that is set up as the server (on page 13). The name can
be entered directly or selected from a list using the ... button.
b) Project name: Name of the project that runs on the server.
c) Project target folder: Folder for Runtime on the client's local hard drive. You either
can select an existing directory using the … button or type it in by hand. If a folder that
does not exist is entered by hand, this is created automatically.
d) Confirm the settings with OK.
erorr:
zenon Module.bin cannot created or is write protect zenon runtime stop
