I use IEC850 Driver Configuration Wizard to configure the drivers but when I click Apply, it always appears the error log: Configuration Failed for whatever changed: creat new driver, change existing driver name, add new report, manually or from *.cid file.
In other way, I still can configure the driver manually one by one (don't use wizard) successfully. And all the drivers I created manually appear in the Wizard
I guess that the tool access successfully to SQL database but cannot apply any change
Can anyone give me the idea what 's wrong with the Wizard or I miss anything?
Zenon version: 11
OS: Windows 10 Pro
