Hi,
I am having trouble importing variables through XML. When select the XML file, zenOn just hanging( stuck) there and without doing anything. So I have to manually shutdown the ZenOn and it never import variables.
To find the problem, I created sample test variables and export them to XML file. Then I deleted the original variables to avoid conflict. Then, import variables using the exported XML file. Zenon still could not import the variables and it got stuck. Uninstall and reinstall ZenOn. but, still the problem exists. practically, I can not import any variables. It does for every projects. I tried the demo project. but no luck
However, screens and functions works fine.
Can you help?
Thank you
This is a migrated post! Originally posted on 11.12.2013 by user abcd1234. Please be aware that information can be outdated.
