Hello all,
Zenon Sankey is limited to only 26 Inputs and 26 Outputs. Is there a way to customize the WPF element in order to accept more than 26 in/out ?
P.S. I used the Sankey Wizard to make the XML file and then used the .cdwpf as a WPF and set the zName to the XML file I have created. The Sankey is working perfectly fine but its limited in IO's.
Regards.
