Workspace file cached locally?
Hi,
I have experienced quite a strange issue while working with the Zenon editor across different machines, with the editor losing changes when editing on a different machine to the previous time. Maybe you can advise what may be the cause....
Some basic info:
Server = Windows 2012 server
Client = Windows 7 64 bit
Network... basic windows workgroup (no domain)
Copadata = Zenon Energy Edition 7.50
So essentially the problem is this. The workspace is stored on the server in C:\Users\Public\Documents\Copadata\\
I have the runtime running on server & client, working away ok. The last time I edited the project I opened the editor up on the server and made changes. All ok so far.
This time I opened the editor on the client machine. I pointed the editor to \\\Users\Public\Documents\Copadata\\
Now the 'workspace' that appears is an OLD version of the workspace... it has lost all the changes the last time I made them on the server. To test I made some changes to the workspace then closed it down. I then opened the ediotor on the server again. Once more the changes I made on the client are not in the workspace.
The solution for this was to make a workspace backup after working on it on one machine & restoring from the other machine (to the same shared drive on the server). My question is how can this happen when the workspace is saved in the same place... on the server?
Is there some kind of local caching happening in the Zenon editor? Have you seen something like this before?
Many thanks,
Dave
This is a migrated post! Originally posted on 17.11.2016 by user HMIdeveloper123. Please be aware that information can be outdated.
