Dear All,
My PLC is having PID Controller logic.
I am sending the Set point values to PLC.
I assigned the limits (Signal area min, max and Measuring range min, max) to the variable.
When I am entering the value below or above from the limits there is one default warning POP-UP (ref: Warning.jpg) is opened like "New value must be between the limits".
But I would like create a customized POP-UP window instead of default Zenon POP-UP according to the customer requirement.
For Example:
Set Point of PID:
If the limit is exceed from the max range of variable then the warning is like "The limit is exceed with respect to PT. Please Enter the correct SP".
If the limit is below from the min range of the variable then the warning is like "The limit is below with respect to PT. Please Enter the correct SP".
Can you please explain, how can we create this Customized POP-UP?
Best Regards,
A.Navaneet.
This is a migrated post! Originally posted on 26.09.2013 by user navaneet. Please be aware that information can be outdated.
